After replacing the serpentine belt, both the A/C and the radiator fans are not working?
HAJ ALLALI
MEMBER
2007 HONDA CRV
2.2L
4 CYL
4WD
MANUAL
80,000 MILES
The car does not heat up and the gauge is on normal for the temperature. The A/C is blowing air.
Tuesday, April 2nd, 2024 AT 2:25 PM
KEN L
MASTER CERTIFIED MECHANIC
You might have disconnected the wiring to the fan module, so please check that. here is a guide and the fuses we must check first before we move forward. This guide can help and the fuse location in both under hood and under dash fuse panels or in the images below.
