Air conditioner not working properly?
YUSUF ÇöLLüER
  • 2009 TOYOTA AURIS
  • 1.4L
  • 4 CYL
  • TURBO
  • 4WD
  • 200,000 MILES
The air conditioner have it's gas fully but cooling doesn't work when A/C mode is open. I believe it is not a serious hardware problem but about fuse. Where shall I check?
Thursday, April 18th, 2024 AT 3:46 PM
  • 108,254 POSTS
This specific model isn't offered in the US, so I don't have the specifics as far as fuses and wiring. However, I will try my best to help.
When you turn on the A/C, does the A/C compressor engage? You should hear it click if it does.
Let me know that first. Also, take a look at this link and let me know if it helps:
One other question I have. Let me know what both the high and low side pressures are and the outside (ambient) temperature when checked.
Thursday, April 18th, 2024 AT 6:55 PM
