Air ride light on?
POWELLCFSR
  • 1998 LINCOLN CONTINENTAL
  • 4.6L
  • V8
  • 106,766 MILES
Changed rear airbags, changed the air compressor, and the car still sags in the back.
Monday, April 10th, 2023 AT 1:03 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
When you turn the key on do you hear the compressor running? If no I would check the fuse #28 in the interior fuse panel and fuse number 4 and 11 in the fuse panel under the hood. If the fuses are good let's swap out the compressor relay above the right cooling fan.
Here is a guide to help and the air suspension wiring diagrams so you can see how the system works:
Tuesday, April 11th, 2023 AT 9:55 AM
