HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-350
Tires
Alignment
SPONSORED LINKS
Alignment specs needed
BRADLEY KENNEDY
MEMBER
1985 FORD F-350
6.9L
V8
2WD
MANUAL
400,000 MILES
Can someone give the alignment specs for the truck listed above?
Friday, March 6th, 2020 AT 6:09 PM
MECHANIC
I attached the specs for camber and caster. Then the entire process. Let us know if you need more info. Thanks
Images (Click to make bigger)
SPONSORED LINKS
Friday, March 6th, 2020 AT 6:18 PM
BRADLEY KENNEDY
MEMBER
Thank you! Was exactly what I've been looking for.
Friday, March 6th, 2020 AT 6:30 PM
MECHANIC
You are welcome. Come back anytime you need other info. Thanks for using 2CarPros.
Saturday, March 7th, 2020 AT 5:07 PM
Please
login
or
register
to post a reply.
Related Alignment Content
2004 Ford F350 Tire Size
I Have Installed The Factory Rims And Tires Off Our 2008 F350 (king Ranch Desiel) The Tire Size Is 275 / 65 R20 On My 2004 F350 (king...
Asked by
superdutyfan
2004
FORD F-350
Tire Replacement
Can I Replace The Originial Lt275/70r18 Load Range E Tires With Lt265/70r18 Load Range E Tires Without Any Adverse Effects Other Than Very...
Asked by
Loyal Eddie
2 IMAGES
2006
FORD F-350
1994 Ford F350
I Have A 1994 F350 Crewcab Which I Have Owned Since New. The Truck Has 149,500 Miles On It. At Times The Steering Shakes So Bad I Have To...
Asked by
Craig Leonhardt
1 ANSWER
1994
FORD F-350
Tiresof Different Size Problems?
What Is The Deal With Changeing Your Tire Size On A 96 F350 Diesiel4x4 I Know Its A Stupid Question But Never Really Got A Real Answer. But...
Asked by
bigo
1 ANSWER
FORD F-350
Ford E-350 Tire Question
Hello, I Just Bought A Used 1990 Ford E-350 Van With The 7.5l Engine. It Came With 4 New Tires, Tl 235/85/16r. I Have Another Van That...
Asked by
muabao
1935
FORD F-350
VIEW MORE
SPONSORED LINKS
Ball Joint
Tie Rod End Replacement Mercedes Benz
Upper Control Arm Replacement
Online car repair manuals
