When the engine is running the brake pedal goes
FREDWS
  • 1988 LINCOLN TOWN CAR
  • 5.0L
  • V8
  • 125,000 MILES
Break pedal go to floor only when engine is running. I have heard pedal that is high when engine is off. I changed master cylinder. Bled all the lines. I have no leaks in system.
Thursday, June 29th, 2017 AT 10:22 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
This sounds like you have a caliper slide that is frozen. This will cause the rotor to push the pad back into the caliper making an air gap.
Here is a guide that shows the caliper slides.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Please let us know what you find.
Cheers, Ken
Friday, June 30th, 2017 AT 12:58 PM
