Check Engine Light is on and the car is shaking?
MICHAELIU
  • 2000 TOYOTA SIENNA
  • V6
  • 160,000 MILES
The check engine light is on but it’s not flashing. It has a weak ignition, so when I started the engine, its power was not that strong. And when I hit the accelerator slightly the car shakes but if I hit it strong and the speed comes up, it doesn’t shake. In addition, when I hit the brake and the speed goes down it starts to shake again. What is more, the battery is old.
Tuesday, August 29th, 2023 AT 3:11 PM
  • 108,489 POSTS
You need to start by having the computer scanned for diagnostic trouble codes. Since the light is on, there will be codes stored. Here is a link that explains how it's done.
Also, most parts stores will scan the computer for you free of charge, so have that done.
Next, often times a rough idle is caused by an engine vacuum leak. I would check to see if you can locate any.
Here is a link that explains how to do it:
Let me know if you have already tried these two things. If you have and have codes, let me know what they are.
Tuesday, August 29th, 2023 AT 7:37 PM
