1972 Chevy Chevelle oil drips from oil fill cap
RICKSS
  • 1972 CHEVROLET CHEVELLE
Engine Performance problem
1972 Chevy Chevelle V8 Two Wheel Drive Manual
Have oil that drips from the oil fill cap on a 1972, 454. Drops on the header, smokes and stinks and making a mess. Any ideas how to stop it?
Thanks for any help
Friday, August 27th, 2010 AT 3:39 PM
Check the condition of the cap if okay-check and test the positive crankcase ventilation system-start at the PCV valve
Friday, August 27th, 2010 AT 3:49 PM
RICKSS
  • 6 POSTS
Oil cap is in good condition, will replace the PCV. On a 454 should there be 2 PCVs (one on each side) or one will work fine?
Thanks for the reply
Friday, August 27th, 2010 AT 4:03 PM
There's only one PCV valve
Friday, August 27th, 2010 AT 4:05 PM
RICKSS
  • 6 POSTS
Replaced PVC and oil cap, after a 15 minute drive, problem back again, drips from the oil cap?
Any help?
Monday, August 30th, 2010 AT 8:39 PM
Sounds like you need to rebuild the engine due to excessive blowby
Monday, August 30th, 2010 AT 9:28 PM
HMAC300
  • 48,600 POSTS
If you have a gauge small enough take teh oil filler cap off and see what the pressure is. If it's above 3psi then something is pressurizing the engine like no breather or blowby. There should be a hose leading to the air cleaner with a small filter to let the engine breathe as well as pcv.
Thursday, December 16th, 2010 AT 4:10 PM
