Fuses where are they?
SGREVES
  • 2004 CHEVROLET TAHOE
My front door passenger mirror side will not work, but the drivers mirror does not. I need to check the fuses where are they?
Monday, March 24th, 2008 AT 11:09 AM
  • 108,489 POSTS
If you look below, I attached the fuse information requested. The first fuse box listed is under the hood. The second is in the vehicle. The legends follow the fuse box pictures.
When you check a fuse, not only should the fuse be checked, but also power to and from the fuse should be checked.
I hope this helps. Let me know if you have other questions.
Thursday, July 1st, 2021 AT 11:55 PM
