Cooling fan, does the radiator have to be removed to change the fan condenser unit?
CREWCHIEF
MEMBER
2012 FIAT 500
4 CYL
2WD
110,000 MILES
Fan blades are broken, does the radiator have to be removed to change the fan condenser unit?
Wednesday, January 10th, 2024 AT 11:00 AM
KEN L
MASTER CERTIFIED MECHANIC
The radiator does not need to be removed but it does need to be loosened from its mounts. Also, the front fascia and bumper cover will need to be removed. I would start by disconnecting the battery. Here are the instructions on how to replace the radiator cooling fan. Check out the images (below). Let us know how it goes.
