HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Crankshaft
Sensor
Location
Where is the crank shaft position sensor located?
JEZZM
MEMBER
2010 FORD TAURUS
3.5L
6 CYL
2WD
AUTOMATIC
190,000 MILES
Crank shaft position sensor location needed.
Sunday, August 27th, 2023 AT 6:56 AM
KEN L
MASTER CERTIFIED MECHANIC
Here are the location and the instructions on how to change out the crankshaft position sensor. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, August 27th, 2023 AT 3:58 PM
Please
login
or
register
to post a reply.
Related Crankshaft Sensor Location Content
Crankshaft Position Sensor Located
6 Cyl Automatic 105000 Miles Where Is The Crankshaft Position Sensor Located On A 2003 Ford Taurus? Please Help Me! I Love This Site
Asked by
TJLAPKA
2 IMAGES
2003
FORD TAURUS
Crankshaft Position Sensor Location
Where Is It Located Under The Hood? Any Pictures Will Be Great. Thanks
Asked by
mido2man
8 IMAGES
2008
FORD TAURUS
Crankshaft Position Sensor Location?
I Have The Car Listed Above And I Took It To Autozone And Had It Put On The Code Because The Check Engine Light Was On And It Was Running...
Asked by
KMart78
1 ANSWER
3 IMAGES
2003
FORD TAURUS
2002 Ford Taurus 02 Taurus Cuts Off When I Get On...
I'm Having Problems With My 02 Ford Taurus Cutting Off Like Its Not Getting Gas. Once I Get Off My Brakes It Cut Off But Will Crank Back Up...
Asked by
tjones1
37 IMAGES
2002
FORD TAURUS
Can Obd-ii Scanner Detect The Error If Crankshaft...
I Used Obd-ii Scanner To Test My Ford Taurus (98) And Found No Error. But The Technican Thought The Crankshaft Sensor Might Be...
Asked by
justingss
1998
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Engine Not Starting - Top 3 Easy Steps
Online car repair manuals
