Cylinder head torque specs and sequence needed?
IMFUKNKRAZY
  • 2004 PONTIAC GRAND PRIX
  • 3.8L
  • V6
  • 188,000 MILES
Need torque specs and sequence. Supercharged.
Tuesday, May 7th, 2024 AT 6:14 PM
  • 108,489 POSTS
If you look below, I attached both the torque specifications, torque sequence, and all info related to doing the job.
When you do this, the head bolts should be new. The old ones will be stretched, and the correct torque will not be reached.
Let me know if this helps.
Tuesday, May 7th, 2024 AT 7:35 PM
