HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Steering
Tie Rod End
Replace/Remove
Replacing inner tie rods. Instructions?
KENNY218
MEMBER
2000 DODGE CARAVAN
What's the name of the special wench needed to replace the inner tie rods? Do you have a repair process from the manual?
Sunday, May 2nd, 2010 AT 2:17 PM
SQM
MECHANIC
Here is a helpful guide to replace tie rod ends:
https://www.2carpros.com/articles/tie-rod-end-replacement
I have attached the replacement procedure for your vehicle.
Let me know if you have any questions.
Images (Click to make bigger)
SPONSORED LINKS
Thursday, July 15th, 2021 AT 9:33 PM
Please
login
or
register
to post a reply.
Related Tie Rod End Replace/Remove Content
2000 Dodge Caravan Front Wheelhub Assembly
Drive Train Axles Bearings Problem 2000 Dodge Caravan 6 Cyl Two Wheel Drive Automatic I Have To Change The Front Wheel Hub Assembly...
Asked by
lejjc
1 ANSWER
2000
DODGE CARAVAN
GUIDE
Tie Rod End Replacement
EV's and gas power cars are equipped which tie rod ends which is needed to connect the rack and pinion or steering box to the spindle and front wheels that control the...
2006 Dodge Caravan Loose Tie Rods Need Replacement...
I'm Driving 600 Miles This Weekend. To A Family Wedding. Midas Muffler Says The Tie Rods Are Loose And Must Be Replaced Now For $300.00...
Asked by
johnpeltzer
1 ANSWER
2006
DODGE CARAVAN
1999 Dodge Caravan Changing The Outher Tie Rods
Steering Problem 1999 Dodge Caravan 6 Cyl Two Wheel Drive Automatic Im Having Problems Changing The Outher Tie Rods I Broke The Nuts...
Asked by
nakiar
1 ANSWER
1999
DODGE CARAVAN
1994 Dodge Caravan Bent Tie Rod
Steering Problem 1994 Dodge Caravan 6 Cyl Front Wheel Drive Automatic I Have A Bent Tie Rod On The Drivers Side Do I Have To Replace...
Asked by
eaglewolf
1 ANSWER
1994
DODGE CARAVAN
1998 Dodge Caravan Outer Tie Rods
I Took My Car In To Get The Water Pump Replaced(which Cost Me 250 Bucks. Yikes!) And They Told Me That The Thunking And Vibration In The...
Asked by
angela15517
1 ANSWER
1998
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Steering Wheel Shaking
Power Steering Pump Replacement
Steering Intermediate Shafts Replacement
Online car repair manuals
