1999 Dodge Dakota Spare Tire
BROBUSH
  • 1999 DODGE DAKOTA
Tires and Wheels problem
1999 Dodge Dakota V8 Two Wheel Drive Automatic
The spare has not been removed in about 3yrs. Now I have to get it off, but the cable system that holds it in place won't work (broken?). How can I get the spare off without damaging the aluminum rim?
Sunday, December 14th, 2008 AT 1:19 PM
  • 108,489 POSTS
Hi:
I recommend spraying the cable and gear assembly with WD40 or the =. Allow it to sit over night, tap on everything lightly with a hammer and see if it works. If it doesn't, you'll have to cut the cable.
Let me know how it goes.
Monday, December 15th, 2008 AT 6:09 PM
BROBUSH
Thanks Joe, but the tire is in the way. I can't even see any of the assembly. I think I'll have to cut the bracket that holds the tire up.
Tuesday, December 16th, 2008 AT 12:02 PM
  • 108,489 POSTS
Hi:
Are you able to get anything under the tire / wheel and pry? There has to be a way.
Tuesday, December 16th, 2008 AT 2:38 PM
