Driver's side brake light not working?
CARP1187
  • 1996 CHRYSLER CONCORDE
  • 3.3L
  • V6
  • 201,112 MILES
I have checked fuses, relays, bulbs, changed multiple bulbs, and my bulb will work when the taillights are on but then again when I hit the brake light on driver side it does not light up.
Sunday, April 16th, 2023 AT 6:43 PM
  • 108,489 POSTS
At the lamp assembly, there should be a white wire with a tan tracer. See pic attached. Have you checked that wire on the left lamp assembly for power? I ask because the light socket itself may be failing. If there is no power, we need to trace that wire to where power is found.
Also, the bulb you're installing is a dual-element bulb, correct? (Bulb 1157)
Sunday, April 16th, 2023 AT 9:57 PM
CARP1187
Yes, I have checked I am getting power.
Sunday, April 16th, 2023 AT 10:13 PM
  • 108,489 POSTS
If you are getting power, confirm there is continuity to ground via the black wire. If there is, then the socket has likely failed.
Let me know what you find.
Tuesday, April 18th, 2023 AT 6:37 PM
