The driver's door electric lock does not open from the inside?
MARCIA ROBERSON
MEMBER
2006 SCION XB
4 CYL
2WD
AUTOMATIC
160,000 MILES
What should I check?
Thursday, September 29th, 2022 AT 5:39 PM
MECHANIC
Will it open with the key FOB? If it does, then we need to check the switch itself. Do any of the other locks work when you press the lock button on the driver's side?
