Driver side Automatic sliding door will not open
SPAZZZ
  • 2006 HONDA ODYSSEY
  • 3.7L
  • V6
  • FWD
  • 77,500 MILES
Just bought it a week ago, the drivers side sliding door will not open automatic. Opens manually. Already tried resetting by pulling fuse, that did not work. When I pull the handle it beeps three times, also beeps three times when using switch on dash, but it will not open. When I manually close I did not completely close it and used the switch and could hear the motor pull it shut all the way. Regards, Joe
Sunday, May 8th, 2016 AT 1:27 PM
HMAC300
  • 48,600 POSTS
Check items in picture for switch bad. If not that then have a mechanic scan for codes.
Sunday, May 8th, 2016 AT 1:49 PM
