Electrical short troubleshooting?
DEBMOZ37
  • 2005 HYUNDAI SANTA FE
  • 2.7L
  • 6 CYL
  • 143,000 MILES
I’m trying to find out if I have a short in my electrical wiring somewhere. The AC would turn off/on like a light switch intermittently, even when no one touches the ac controls. Other things have stopped working suddenly then started back up also. I’m just trying to find out where I should start troubleshooting and how since I don’t know much about electrical wiring, etc. Thank you
Thursday, November 9th, 2023 AT 8:17 AM
DEBMOZ37
I just saw the page that helps with repairs. I’ll look at that first and respond with any questions afterwards. Thank you so much.
Thursday, November 9th, 2023 AT 3:52 PM
  • 108,489 POSTS
No problem whatsoever. When you respond, let me know what other electronics are doing the same. Also, if it was a short, it should cause a fuse to fail. As a result, the component wouldn't turn back on until the fuse was replaced. What you described sounds like a connection issue. That is why knowing the other components affected will help me narrow things down.
Let me know if I can help.
Thursday, November 9th, 2023 AT 9:02 PM
