I’d like to know if you can swap a 4T1BE engine with a 2AZ-FE engine.
Tuesday, April 16th, 2024 AT 11:11 PM
KEN L
MASTER CERTIFIED MECHANIC
One is a 4 cylinder, and the other is a 6 cylinder so I don't recommend doing this, it would be cheaper to get the car with the 6 cylinder already in it. The wiring harness, exhaust system, PCM, engine mounts, too many things to list will need to be changed.
