HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-350
Emission
EGR Valve
Location
SPONSORED LINKS
Where is the EGR valve located
SMAKWATERJACK
MEMBER
2006 FORD F-350
V8 Two Wheel Drive Automatic.
where is the EGR valve located on the truck listed above with a 6.0 power-stroke v-8?
Friday, June 26th, 2009 AT 1:19 PM
BLUELIGHTNIN6
MECHANIC
The EGR valve should be seated in the intake manifold held by two bolts.
SPONSORED LINKS
Friday, June 26th, 2009 AT 3:47 PM
BMDOUBLE
MECHANIC
There are special procedures for removing the valve because of excess carbon build-up. I have attached the procedure and special tool numbers.
Images (Click to make bigger)
Monday, July 13th, 2020 AT 12:59 PM
Please
login
or
register
to post a reply.
Related EGR Valve Location Content
1988 Ford F350 Egr Valve
Engine Performance Problem 1988 Ford F350 V8 Could You Please Tell Me Where The Egr Valve Is Located In Our 1988 Ford Truck F350?
Asked by
titch017
1988
FORD F-350
2008 Ford F350
Hi, My Name Is Dave I Have A 6.4 Liter Diesel That I Need Help With. Here Is The Problem: When I Run My Truck And Shut It Off Or...
Asked by
hoganman
2008
FORD F-350
1988 Ford F350
It Was Throwing 4 Different Codes, I Replaced The Hpfp, Egr Valve, Egr Selonoid, Air Pressure Temperature Valve, Now It Is Not Showing...
Asked by
cherri_1152
1 ANSWER
1988
FORD F-350
SPONSORED LINKS
Code Read Retrieval/Clear Chevrolet
Topdon OBD2 Scanner Review - This thing rocks
Code Read Retrieval/Clear Honda
Online car repair manuals
