1991 Ford Mustang fuel tank
VINCESANT
  • 1991 FORD MUSTANG
Engine Mechanical problem
1991 Ford Mustang 6 cyl Two Wheel Drive Manual
there are 2 loose pans in my fuel tank. What are they and where should they be? Is there anyplace where I can get a diagram/pictures of what it should look like?
Thank you
Monday, March 15th, 2010 AT 10:42 PM
  • 31,937 POSTS
Hi there,
I would think that they are tank baffles that have come loose, they are designed to stop the fuel sloshing around to much, they would normally be spot welded in place (if a steel tank) I can find no pic to show this. Is the tank steel or plastic?
Mark (mhpautos)
Tuesday, March 16th, 2010 AT 3:24 AM
VINCESANT
The tank is metal. Do I need to have them welded?
Thanks a lot, Mark
Tuesday, March 16th, 2010 AT 8:12 PM
  • 31,937 POSTS
Hi there,
If these are looses baffles, you will have to get another tank, as it will not be cost efficient to get it repaired I feel, just have a word to a radiator repairer as they could do this for you.
Mark (mhpautos)
Tuesday, March 16th, 2010 AT 9:07 PM
