When I turn the key to on the fuel pump does not run. What is the cause and what to check?
Wednesday, May 25th, 2016 AT 4:44 PM
K3N3T1K_K
MEMBER
How old is your (Ecm or Ecu)? And have you checked the fuses as well, and checked the wires to the fuel pump to see if they are getting power? If you do not hear the priming of the the fuel pump, its not getting fuel at all.
SPONSORED LINKS
Wednesday, May 25th, 2016 AT 4:52 PM
JOE1953
MEMBER
I do not know how old is the Ecm or Ecu I have not check the fuses and the wires where are the fuses located? I do not hear the priming of the fuel pump when turn the key on.
Wednesday, May 25th, 2016 AT 5:02 PM
K3N3T1K_K
MEMBER
Also, check if it has a fuel pump relay or main relay.
Wednesday, May 25th, 2016 AT 7:15 PM
HMAC300
MECHANIC
Try resetting security system if no manual look online for your car on how to do it. Also, check the battery cables as they may be dirty causing the security system to engage. When it does it shuts fuel off.
