Tailgate will not open
RONJANEXUV
  • 2004 GMC ENVOY
Other Category problem 6 cyl Four Wheel Drive 49,000 miles
The tailgate will not open. When I sqeeze the pressure switch that releases the tailgate, nothing happens. Both of the pressure switches for the tailgate are not working. What would cause both of them not to work. Is there a way to manually open the tailgate?
Tuesday, January 8th, 2008 AT 12:53 PM
JB2BNVD
I'm having the same problem. Is there a wiring diagram available. Owners manual doesn't even show a fuse.
Tuesday, February 17th, 2009 AT 10:18 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
There is a fuse #3 and #23 that need to be checked to see if they are blown. Here is a guide to help you with that.
If you can hear something working in the tailgate then it is having a mechanical issue and you will need to remove the inner panel to inspect. Here are some diagram (below) that will help us get the problem fixed.
Please let us know what you find.
Cheers, Ken
Tuesday, September 19th, 2017 AT 11:43 AM
