Can someone please give me the exact wiring diagram for the alternator starter and battery?
Tuesday, April 30th, 2024 AT 2:17 PM
MECHANIC
If you look below, there are two wiring schematic pictures. The first one is for the charging system and the second one is the starter (automatic transmission). Take a look at them and let me know if they help.
Also, let me know what is happening. I should be able to help.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, April 30th, 2024 AT 7:08 PM
BRANDYBMB78
MEMBER
Recently had to put belt back on the alternator and now car acting crazy lights flicker hardly no power when put in gear and mash gas.
Wednesday, May 1st, 2024 AT 5:42 AM
MECHANIC
When you say the lights are flickering, do you mean things like the headlamps or are you referring to the cluster warning lights?
Do me a favor. I want to know what the alternator is doing. Here is a link that explains how to test one. It is very easy and only requires a voltmeter or multimeter.
