Intermittent will not crank issue?
UNDERTOW_31
  • 2008 MITSUBISHI ENDEAVOR
  • 6 CYL
  • 165,000 MILES
My car will not crank sometimes. I just have to be patient and try it out for 10 minutes or so and it will eventually turn over. Sometimes I will go out and it starts right away, but I am not interested in being stranded. Once the car is on, it stays running so I don’t think it is an alternator and it has a new battery with clean connections. I don’t hear any strange noises coming from the starter, but I suspect it may be the issue. Any help would be appreciated.
Monday, July 24th, 2023 AT 4:53 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Most of the time the problem will be the starter because it will have a bad spot that will get worse with time, but to be sure we can use a test light on the trigger wire when the engine is not cranking over.
This guide will help, and I have included how to swap out the starter motor in the images below:
Check out the images (below). Please let us know what you find.
Tuesday, July 25th, 2023 AT 7:07 PM
