Automatic temperature control does not work. Fuse and relay is good, put in new thermostat.
Monday, January 2nd, 2017 AT 10:24 AM
HMAC300
MECHANIC
This will need to be scanned for codes to see what Is wrong with it. Check fuses in picture.
Image (Click to make bigger)
SPONSORED LINKS
Monday, January 2nd, 2017 AT 12:03 PM
KEN L
MASTER CERTIFIED MECHANIC
FROM BOB B
I looked at the fuses they all look good if it is the control head how
would I check it?
Wednesday, January 4th, 2017 AT 9:28 AM
KEN L
Hey Bob,
You must check the power and ground input and outputs of the system, here is a complete wiring diagram that will show you how to test the controller and the wiring.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Images (Click to make bigger)
Wednesday, January 4th, 2017 AT 9:35 AM
BOB B
MEMBER
I put a new automatic temperature control head in now it lights up ran a diagnostic test and no codes came up but still no heat
Friday, January 6th, 2017 AT 11:23 AM
HMAC300
MECHANIC
Check to see if blend door is getting power but it may be a sensor that is screwing up that is why you need to get it scanned for codes.
SPONSORED LINKS
Friday, January 6th, 2017 AT 12:01 PM
BOB B
MEMBER
How do I change the blend door unit
Monday, January 9th, 2017 AT 10:34 AM
HMAC300
MECHANIC
Sorry I gave you the wrong instructions for resetting actuator see pic also covers getting codes if not the actuators
Monday, January 9th, 2017 AT 12:04 PM
HMAC300
MECHANIC
For somereason I can't add images to say what to do
Monday, January 9th, 2017 AT 12:06 PM
HMAC300
MECHANIC
Ok now have pics
Monday, January 9th, 2017 AT 12:13 PM
BOB B
MEMBER
Can you show me what a in car ambient temperature sensor looks like please which is behind the right bezel thank you.
Monday, January 9th, 2017 AT 2:53 PM
HMAC300
MECHANIC
See pic it's a two wire connector
Monday, January 9th, 2017 AT 3:30 PM
KEN L
Hey Bob,
I found these images for you to show you where the blend door actuators are.
Please let us know happens so it will help others.
Best, Ken
SPONSORED LINKS
Monday, January 9th, 2017 AT 3:53 PM
BOB B
MEMBER
As soon as I put in the sensor ill let you now if every thing works thank you for your help
Monday, January 9th, 2017 AT 4:32 PM
KEN L
Sounds good, please let us know.
Best, Ken
Tuesday, January 10th, 2017 AT 11:07 AM
BOB B
MEMBER
Do you know where I can find a in-car temp sensor
Saturday, January 14th, 2017 AT 3:03 PM
KEN L
IN-VEHICLE TEMPERATURE SENSOR
Removal & Installation
Remove right side instrument panel trim end cap and trim bezel from instrument panel. Remove sensor screws, pull out sensor, and disconnect wiring. To install, reverse removal procedure.
Saturday, January 14th, 2017 AT 9:38 PM
BOB B
MEMBER
Do you know where I can find a in vehicle temp sensor can't seem to find one?
