How to remove the High-Pressure Fuel Pump connector?
FARMERW
  • 2015 CHEVROLET IMPALA
  • 3.6L
  • 6 CYL
  • 140,000 MILES
I am unfamiliar with this type of connector. How do I release it to remove? I don't want to break it. See attached picture. It has a blue ear on the visible side.
It is only a 2-pin connector.
Tuesday, April 9th, 2024 AT 2:51 PM
  • 108,489 POSTS
The blue tab is a safety to prevent it from coming off. It should slide out from the connector and then you should be able to depress the release and remove the connector.
Tuesday, April 9th, 2024 AT 7:39 PM
FARMERW
Thanks. The connector was quite brittle. Blue part broke but was able to maintain the key locking feature for re-installing. Thanks.
Tuesday, April 9th, 2024 AT 9:39 PM
  • 108,489 POSTS
You are very welcome. As far as the connector is concerned, the heat causes them to get that way. If it didn't fall apart, you did good! LOL
Take care of yourself and feel free to come back anytime in the future.
Wednesday, April 10th, 2024 AT 6:02 PM
