Pressing the horn on steering wheel makes no sound. The horn works via remote panic button. I took wheel apart and find there is no power to the horn switch. Fuse for horn checks fine, can't seem to find a "horn " relay.
Thoughts?
SPONSORED LINKS
Monday, February 18th, 2019 AT 1:38 PM
SCGRANTURISMO
MECHANIC
It does sound like the horn relay. In the diagrams down below I have included everything that you will need to fix your vehicles problem. Let us know what you find out.
Thanks,
Alex
2CarPros
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, February 19th, 2019 AT 10:32 AM
F1SH0N
MEMBER
Thank you for the information. I suspect it's the clock spring (a little loose and makes a slight rubbing sound) but will verify now that I can actually check connections.
Really appreciate your assistance!
Wednesday, February 20th, 2019 AT 10:28 AM
KEN L
MASTER CERTIFIED MECHANIC
SCWICKEDSTANG is quickly becoming our best! Please let us know if you need anything else to get the problem fixed.
