Coolant temperature sensor replacement and location please!
SSTEVEN
MEMBER
2011 FORD TAURUS
183,000 MILES
Fan not running. How do I replace the temperature sensor?
Sunday, January 7th, 2018 AT 9:50 AM
SATURNTECH9
MECHANIC
Just wait until the engine has completely cooled down unplug the sensor. Then get the new sensor ready to install it. Then unscrew the new sensor and quickly swap over the new sensor before you lose a lot of coolant. Also, just because the fan does not work does not mean it is the sensor it could be the fan motor etc. Here are diagrams to help you find the location for replacement. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Sunday, January 7th, 2018 AT 3:36 PM
CHADRICK RILEY
MEMBER
1 POST
2003 FORD TAURUS
3.0L
205,299 MILES
Coolant sensor location on my car.
Tuesday, June 8th, 2021 AT 5:52 PM
(Merged)
SCGRANTURISMO
MECHANIC
Your vehicle's Engine Coolant Temperature Sensor (ECT) is located on the back of the engine near the thermostat. In the diagrams down below I have included a diagram of the ECT. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Image (Click to make bigger)
(Merged)
JMGONZALEZ
MEMBER
1 POST
1999 FORD TAURUS
6 CYL
FWD
AUTOMATIC
114,000 MILES
Where can I find the heating sensor on a 1999 ford taurus wagon
(Merged)
BLUELIGHTNIN6
MECHANIC
If you are referring to the engine coolant temperature sensor than it is located on the rear of the engine block near the thermostat
Here is a diagram below:
SPONSORED LINKS
(Merged)
GRAFFIXX808
MEMBER
1 POST
1995 FORD TAURUS
Where is the engine coolant temperature sensor located?
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
the engine coolant sensor is located at the top front of the engine near the distributor. Here is a guide that will show you what you are in for when doing the job.
Cheers, Ken
(Merged)
KINGVISION
MEMBER
1992 FORD TAURUS
130,000 MILES
My temperature gauge has been fluctuating and I believe the temperature sending unit may be bad.
Tuesday, June 8th, 2021 AT 5:53 PM
(Merged)
RIVERMIKERAT
MECHANIC
Image #1 1992 Ford Taurus 3.0 sensors locations on the top left side of the engine.
Image #2 Taurus 3.0 SHO sensors locations, by the throttle body.
Image #3 Taurus 3.8 sensors locations, at the top left rear of the engine.
(Merged)
KINGVISION
MEMBER
Thank you. It was the 3.8 by the way. I had kept thinking that was it, but for some reason it didn't look the same as the one I ordered. Thanks again.
(Merged)
RIVERMIKERAT
MECHANIC
My pleasure. Be sure to tell your friends abut us.
