HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Tires
Pressure Sensor
Tire pressure sensor fault
THUBAYIN
MEMBER
2011 FORD FOCUS
4 CYL
2WD
AUTOMATIC
92,762 MILES
What does tire pressure sensor fault mean?
Tuesday, April 4th, 2017 AT 8:47 AM
HMAC300
MECHANIC
Check what tire it says is low on air. If low fill it to recommended pressure, if light goes out you are good. However, if not then have a tire store check for a leak or bad sensor.
SPONSORED LINKS
Tuesday, April 4th, 2017 AT 9:30 AM
Please
login
or
register
to post a reply.
Related Tire Pressure Sensor Content
Wheel Alignment
Wheel Alignment Specs For 2012 Focus Titanium?
Asked by
mdecello
5 IMAGES
2012
FORD FOCUS
Tire Balance?
Shakes Or Wobbles Problem 4 Cyl Two Wheel Drive Automatic 79,900 Miles I Have A 2003 Ford Focus And Recently I've Noticed That My...
Asked by
acc67
1 ANSWER
2003
FORD FOCUS
2003 Ford Focus Tire Replacement
My Rear Driver Side Tire Went Flat Today And In Searching For A Replacement, I Found That My Car (recently Purchased) Has Two Different...
Asked by
ks2pa2001
1 ANSWER
2003
FORD FOCUS
2001 Ford Focus Speed Ratings
Tires And Wheels Problem 2001 Ford Focus 4 Cyl Automatic 115000 Miles I Am Doing Research For A Set Of Replacement Tires. Ford's Tire...
Asked by
tenorbach
2001
FORD FOCUS
2003 Ford Focus 2003 Ford Focus Sw - Se -vibrates/...
2003 Ford Focus 4 Cyl Automatic 51,000 Miles My 2003 Ford Focus Sw (auto) Is Vibrating At Idle To The Point That You Cannot Use The...
Asked by
TheHardWay
1 ANSWER
2003
FORD FOCUS
VIEW MORE
SPONSORED LINKS
Control Arm Bushing Replacement - Lower
Tie Rod End Replacement
Safely Change Your Spare Tire
Online car repair manuals
