HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Vitz
Engine
Symptoms
Idle Erratic
Idle Problem
ABOOADAM
MEMBER
2005 TOYOTA VITZ
3 CYL
2WD
AUTOMATIC
150,000 MILES
I was cleaned Throttle body. After that idle speed is very high
how to adjust the speed? Or how to solve this?
Tuesday, February 14th, 2017 AT 5:32 AM
HMAC300
MECHANIC
Check for a vacuum leak and scan for codes your idle air control valve may need replacing bt drive it first over 40 mph
SPONSORED LINKS
Tuesday, February 14th, 2017 AT 5:46 AM
Please
login
or
register
to post a reply.
Related Engine Idle Erratic Content
Engine Not Starting
Engine Cranks, But Will Not Start. Found Fuel Oil Not Coming Through The Two Injectors Out Of Three Unit.
Asked by
Swopon Mollah Mollah
2005
TOYOTA VITZ
VIDEO
Vacuum Leak Test and Repair
Instructional repair video
GUIDE
Idling High
Intermittent sensor failure or shorting can cause the computer to act strange with unusual side effects, these problems are particularly tough to diagnose. The computer...
Rattling Sound And Dropping Rpm
Getting Two Problems: 1. The Car Drops Rpm And My Car Vibrates In Low Speed Or In Standing Position. 2. I Get A Rattling Sound In Low...
Asked by
thornofcarrion
1 ANSWER
1 IMAGE
2005
TOYOTA VITZ
Engine Knocks When Acceleration Padel Is Depressed
In My Vitz 2006 Automatic Transmission Car, It Works Fine When Cold That Is The Car Accelerates Normally Feeling The Power With Respect To...
Asked by
razacaa
2006
TOYOTA VITZ
2004 Toyota Vitz Severe Engine Missing And Vibrates
My Car Toyota Vitz Is Doing Severe Engine Missing And Vibrates At Low Rpm. It Gets Autimatically Off. Few Mechanics Declare It As Engine...
Asked by
Asif Khattak
1 ANSWER
2004
TOYOTA VITZ
Fuel Consumption
Sir I Have Toyota Vitz, My Car Giving Only 10 Km Per Litre Without A/c, I Change The Spark Plug, Wash The Injector, Change The Petrol...
Asked by
saqib87
1 ANSWER
1 IMAGE
1999
TOYOTA VITZ
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Idle Air Control Valve
Online car repair manuals
