Will not stay running?
DANIEL JENNIFER PIERCE
  • 1979 JEEP CJ7
  • 4.3L
  • 6 CYL
  • 4WD
  • MANUAL
  • 79,678 MILES
I bought a new 79 cj7. I drove it home a few weeks ago and it did fine. Next day I took it out for a spin, and it shut off on me initially thought ran out of fuel. Have put 7 gallons in it and changed fuel filter. Still not starting it cranks and fires for a second but when you release key it doesn't stay running. Changed ignition module same results.
Friday, February 17th, 2023 AT 9:03 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Thanks for the video and images. Will it stay running if you hold your foot on the throttle slightly? It sounds like either the carburetor has a clogged idle circuit or there is a vacuum leak. I would start by removing the EGR valve and running this test in the video below.
https://youtu.be/DqUCbbKdWf4
If it passes have a helper hold the RPMs up slightly and use this guide to look for vacuum leak when the engine is cold:
Please go over these guides and get back to me.
Saturday, February 18th, 2023 AT 5:15 PM
I actually messed with it today. I have 0-voltage at resistor when key is in run position. I used a jumper wire from battery to resistor headed to coil and it fires right up. Remove the jumper wire and he shuts down.
Not getting any juice from ignition switch. I've got a new ignition switch coming.
Saturday, February 18th, 2023 AT 6:04 PM
KEN L
  • 43,468 POSTS
Good find on that, please let me know if the switch fixes it.
Sunday, February 19th, 2023 AT 11:09 AM
Well, I got to messing around in fuse box and the 30amp fuse for coil was blown so I replaced that, and she fired like a champ last night. But today driving it a little the starter gear is not retracting like it should. It does retract it I clutch and put it in gear. But going down the road every once in a while it sounds like that starter gear is protruding just a bit and occasionally engages with flywheel. Any idea starter or solenoid?
Sunday, February 19th, 2023 AT 11:56 AM
KEN L
  • 43,468 POSTS
The starter index return spring can be weak or broken, I would remove the starter and see if the bendix gear is hanging outward.
Monday, February 20th, 2023 AT 12:30 PM
Is that spring a part that can be purchased and replaced?
Monday, February 20th, 2023 AT 1:23 PM
