Where is the Ignition distributor engine speed input circuit located?
GINGER HOWELL
  • 2005 HYUNDAI XG350
  • 177,000 MILES
Where can l locate this? Code p0320 is showing?
Wednesday, February 7th, 2024 AT 2:51 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Here is the information that is needed to help fix the problem:
The P0320 code on a 2005 Hyundai XG350 is related to the ignition/distributor engine speed input circuit malfunction.
So, this is related to the crankshaft angle sensor or the wiring headed to the sensor which it is common for the timing belt to come apart and damage the wiring to the sensor, either way the timing belt cover must be remove so you can get at the sensor for inspection, if the wiring is okay I would replace the sensor. Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Thursday, February 8th, 2024 AT 11:46 AM
KEN L
  • 43,468 POSTS
Anything?
Friday, May 10th, 2024 AT 5:38 PM
