Turning the key to start the truck, I hear a click and nothing else?
EMRBAMA
  • 1997 NISSAN TRUCK
  • 2.4L
  • 4 CYL
  • MANUAL
  • 189,000 MILES
After turning the key to start the truck, I hear a click and nothing else. Sometimes, it starts fine on the first try, sometimes it clicks then I try 1 or 2 or 3 or 4 times until it starts. Once it starts it idles fine and is good to go. The engine is not cranking over.
Wednesday, November 29th, 2023 AT 6:38 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
This is common when you have a bad connection at the battery or the starter motor is going out, but to be sure let's check the battery cables first.
This guide can help:
If the cables are okay, use this guide to check for power at the trigger wire when the key is in the crank position:
Please go over these guides and get back to us.
Thursday, November 30th, 2023 AT 1:04 PM
