Interchangeable wheel bearing
TONI MITCHELL
  • 2008 CHRYSLER SEBRING
  • 2.4L
  • 4 CYL
  • 88,000 MILES
I ordered the wheel bearing for my car and they sent me wheel bearing for a 200. So I was wondering if I can still use them?
Saturday, May 4th, 2019 AT 3:21 PM
  • 108,489 POSTS
Welcome to 2CarPros.
I looked up part numbers for both the front and rear and for both years. (I don't know which you are replacing) They are different numbers, so with that in mind, I would say it isn't the same.
Once you get that straightened out with the store, here are the directions. First, here is a link that shows how in general one is replaced:
https://www.2carpros.com/articles/bearing-hub-replacement
Here are the directions specific to your vehicle for both the front and rear. The attached pictures correlate with the directions.
_________________________
Front / Hub bearing removal
FRONT HUB / BEARING - REMOVAL
REMOVAL
NOTE: Before proceeding, review all Warnings and Cautions. See: Suspension > Vehicle Damage Warnings > Warnings and Cautions
1. Raise and support the vehicle. See: Maintenance
pic 1
2. Remove the wheel mounting nuts (3), then the tire and wheel assembly (1).
pic 2
3. While a helper applies the brakes to keep the hub from rotating, remove the hub nut (1) from the axle half shaft (2).
4. Access and remove the front brake rotor. See: Brake Rotor/Disc > Removal and Replacement > Brake Rotor - Removal
pic 3
5. Remove the four bolts (2) fastening the hub and bearing to the knuckle (3).
6. Slide the hub and bearing (1) off the half shaft and out of the knuckle.
____
Replacement
INSTALLATION
pic 4
1. Install the hub and bearing (1) by sliding it over the half shaft and into the knuckle.
2. Install the four bolts (2) fastening the hub and bearing (1) to the knuckle (3). Tighten the four bolts to 82 Nm (60 ft. lbs.).
3. Install the brake rotor, disc brake caliper and adapter. See: Brake Rotor/Disc > Removal and Replacement > Brake Rotor - Installation
pic 5
4. Clean all foreign matter from the threads of the half shaft outer C/V joint.
5. Install the hub nut (1) on the end of the half shaft (2) and lightly tighten it.
6. While a helper applies the brakes to keep the hub from rotating, tighten the hub nut (1) to 132 Nm (97 ft. lbs.).
pic 6
7. Install the tire and wheel assembly (1) See: Wheels and Tires > Removal and Replacement > Tires and Wheels - Installation. Install and tighten wheel mounting nuts (3) to 135 Nm (100 ft. lbs.).
8. Lower the vehicle.
Rear Removal
NOTE: Before proceeding, See: Suspension > Vehicle Damage Warnings > Warnings and Cautions.
pic 7
2. Remove the wheel mounting nuts (3), then the rear tire and wheel assembly.
3. If equipped with rear disc brakes, access and remove the rear brake rotor (3). See: Brake Rotor/Disc > Removal and Replacement > Brake Rotor - Removal
4. If equipped with rear drum brakes, access and remove the rear brake drum. See: Brake Drum > Removal and Replacement > Removal
pic 8
5. Remove the screw (1) fastening the wheel speed sensor (2) head in the rear of the hub and bearing.
pic 9
6. Remove the four bolts (1) securing the hub and bearing (2) to the knuckle.
7. Remove the hub and bearing.
_____________________________
Rear Replace.
FRONT-WHEEL-DRIVE
pic 10
NOTE: If equipped, make sure the wheel speed sensor mount on the rear of the hub and bearing is directed toward the front of the vehicle.
1. Position the hub and bearing on the brake support plate and knuckle.
2. Install the four bolts (1) securing the hub and bearing (2) to the knuckle. Tighten the bolts to 105 Nm (77 ft. lbs.).
pic 11
NOTE: Before installing the wheel speed sensor head into the rear of the hub and bearing, inspect the O-ring seal to make sure it is not dislodged, split, cut or damaged in any way. Replace the O-ring as necessary.
3. If equipped with a wheel speed sensor, install the wheel speed sensor (2) head into the rear of the hub and bearing.
4. If equipped with a wheel speed sensor, install the wheel speed sensor head mounting screw (1). Tighten the screw to 10 Nm (89 in. lbs.).
5. If equipped with rear disc brakes, install the brake rotor, disc brake caliper and adapter. See: Brake Rotor/Disc > Removal and Replacement > Brake Rotor - Installation
6. If equipped with rear drum brakes, install the brake drum and adjust as necessary. See: Brake Drum > Removal and Replacement > Installation
pic 12
7. Install the tire and wheel assembly (1) See: Wheels and Tires > Removal and Replacement > Tires and Wheels - Installation. Install and tighten the wheel mounting nuts (3) to 135 Nm (100 ft. lbs.).
9. Pump the brake pedal several times to ensure the vehicle has a firm brake pedal before moving it.
Saturday, May 4th, 2019 AT 8:17 PM
