Inter cooler covered with oil
SM21
  • 2002 VOLKSWAGEN POLO
  • 1.4L
  • 3 CYL
  • TURBO
  • MANUAL
  • 150,000 MILES
Hello everybody,
The intercooler of my car is covered with oil (as you can see on the photos) and I wanted to know if it is a normal thing or not. And if it is not where is the problem? Is it correct that it can be something with the turbo or it might be cracked somehow?
Sunday, November 18th, 2018 AT 4:51 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Yep, the seal in the turbo goes out because the bearings let go causing engine oil to be let into the intake system which includes the inter-cooler. To confirm the issue please remove the inlet tube and check the end play (should have very little). Here are guides to help you change the turbo out to fix the problem. Make sure you clean everything really well before you put it back together.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Monday, November 19th, 2018 AT 2:02 PM
SM21
  • 20 POSTS
Okay Ken I will do the following steps that you are telling and I am going to let you know. So the problem might be the seal in the turbo!
Thank you very much Ken, this is so helpful for me.
Tuesday, November 20th, 2018 AT 3:45 AM
KEN L
  • 43,468 POSTS
No problem please let us know how it goes.
Tuesday, November 20th, 2018 AT 9:35 AM
