Instant milage per gallon stopped working in my dash, how do I repair this?
KEN52
  • 1996 LINCOLN CONTINENTAL
  • 4.6L
  • V8
  • 85,000 MILES
Recently my instant milage per gallon stopped working in my dash. (I recently had a heater core replaced). How would I fix this issue without buying a new dash? It doesn't work on metric also.
This is an original milage Town Car Executive.
Saturday, May 27th, 2023 AT 5:26 PM
  • 108,489 POSTS
Have you inspected the wiring to the circuit? Also, are there any other issues that resulted from the heater core being replaced?
Let me know if there are any other issues. For example, if there is an ABS sensor light on, that could be preventing the computer from calculating MPG. It's a theory. However, since the heater core was replaced, I feel it is likely a loose wire at the dash.
Monday, May 29th, 2023 AT 8:38 PM
KEN52
  • 38 POSTS
Hi Joe, thanks for responding. I'm working with my local mechanic now and the car goes into the shop next week.
That s the only issue I have. The milage will work somewhat for a few minutes then it rolls up to 99 and stops. The metric stops on 2 the goes to 99 the same. Thanks
Wednesday, May 31st, 2023 AT 10:11 AM
  • 108,489 POSTS
Sounds good. If possible, could you let me know what is found? I'm interested in knowing.
Wednesday, May 31st, 2023 AT 9:50 PM
KEN52
  • 38 POSTS
The local mechanic was unable to repair this, cannot isolate part to replace.
Will do some more research online. Take care Ken.
Thursday, June 15th, 2023 AT 2:36 AM
  • 108,489 POSTS
Thanks for the update. Electrical issues can be such a headache. You indicated this happened after the heater core was replaced. I suspect the wiring under the dash was disrupted. It could be a ground wire that was disconnected.
Let me know if you find anything or if you have questions.
Thursday, June 15th, 2023 AT 10:45 PM
KEN52
  • 38 POSTS
The local mechanic ran through all the checks and couldn't find anything, so he quit working on it, hopefully I hear something sometime. Thanks
Friday, June 16th, 2023 AT 12:16 AM
  • 108,489 POSTS
Do you have a shop near you that deals specifically with auto electric issues?
Friday, June 16th, 2023 AT 7:33 PM
KEN52
  • 38 POSTS
No, we don't. Small coastal town mostly log trucks and fishing boats.
Friday, June 16th, 2023 AT 11:27 PM
  • 108,489 POSTS
Wow, I want to live there. I could enjoy that kind of setting.
Anyway, I don't think it is a component issue. Instead, I suspect it is a wiring issue.
Check behind the message center to make sure the wiring isn't damaged, and the connector is good. I attached a pic below showing the switch connector for your reference.
Let me know. When the heater core was removed, they damaged something.
See pic below.
Saturday, June 17th, 2023 AT 9:42 PM
