Left front signal does not flash
JOSH GREENWALD
  • 2003 HONDA ACCORD
  • 3.0L
  • V6
  • FWD
  • 166,000 MILES
All of my signals flash when the hazards are on like normal. However, the left side blinks fast, and I just replaced the bulbs so bulbs are not the issue. This started happening after my car had some front end damage and had the headlights replaced. When the headlights are on, the bulb tries to stay on and flash at the same time rather than only flash as it should. I have no experience with electrical issues/troubleshooting, and I am hoping that there is a cheap way to fix this.
Sunday, November 13th, 2016 AT 3:50 PM
CARADIODOC
  • 33,765 POSTS
Some of what you are describing are the classic symptoms of a broken ground circuit. There are some voltage tests that could confirm that, but given the history, (thank you for including that), start by inspecting the wiring for the affected bulb. I have not dug out a wiring diagram yet, so for now, we will assume you have the typical front turn signal and running light in the same bulb. When that is the case, with a bad ground, the signal bulb will act differently when you turn on the running lights or head lights. Also, when the left bulb doesn't work properly, it will go out completely when you remove the right bulb from its socket. With that bad ground, current wants to go through the left bulb but cannot find the return path to ground. Instead, it travels over to the right bulb which is connected to the same circuit, then goes through it and then to ground on the right side. Removing the right bulb removes the path for current, so the left bulb goes out.
Follow the wires from the socket. One of them must be bolted to the car's body sheet metal or a metal structural part of the car.
Sunday, November 13th, 2016 AT 6:42 PM
