Brake lights and turn signals stop working. I have tail lights and running lights.
Thursday, March 9th, 2017 AT 8:48 PM
HMAC300
MECHANIC
Assuming you have check the bulbs, then it may be a turn signal switch or brake light switch. Check fuses as well. Check fuses and relay in picture first. However, it could be that. If fuse blows again there is a short in system.
