My EGR valve broke due to missing motor mounts(engine was jumpin up when I accelerate), would this be the cause of a hesitation or pause.
JWARE1024
  • 1999 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • 271,000 MILES
My motor mounts came off some how. I noticed that my egr valve broke as I was banging on the firewall when I pressed the gas yo go. I can't say this all happened in one day but. I then started getting a pause before it would take off. If I sat at a red when it turned green I press the gas an the rpm would drop below one and the car would want to die. Bur letting go of the pedal it started idling normally. I have to pump in order to get the engine going. Please help. If u can thatnk u! If u need more info please ask. Justin
Tuesday, March 29th, 2016 AT 5:53 PM
HMAC300
  • 48,600 POSTS
Clean throttle plate on both sides and iac hole with choke cleaner then check fuel pressure with a gauge auto parts rent it. Also make sure motor mounts are fixed.
Wednesday, March 30th, 2016 AT 7:25 AM
JWARE1024
Thanks! I really appreciate you taking time to help me out. Thanks again?
Thursday, March 31st, 2016 AT 2:33 AM
