No power to the instrument cluster?
TMAG89
  • 2011 BMW 328XI
  • 3.0L
  • 6 CYL
  • 4WD
  • 101,000 MILES
The other day I was going through a drive-through and I turned my car off so I could hear the radio at the window. When I stuck the key back in the ignition there was no power to my instrument cluster and my start stop wouldn't do anything. I thought it would be the key fob, so I put a new battery in it and nothing will happen. I've checked all the fuses and the battery is new and fully charged the interior lights come on I can turn on the radio my headlights are working. I'm not even getting a key symbol on the dashboard. My windows are stuck being down because I had them down at the time. If you could please guide me in the right direction, it would be greatly appreciated. Thank you.
Thursday, June 15th, 2023 AT 11:22 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
It sounds like the Footwell module has gone out which is common in these cars, but to be sure we need to do a CAN scan, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Here is how to change the footwell module out in case a code comes up for its failure. You can get a preprogrammed unit by searching Google or Ebay.
Friday, June 16th, 2023 AT 8:14 AM
