Headlights, windshield wipers and turn signals not working?
BULLFROG_23
  • 2007 HONDA ODYSSEY
  • 3.5L
  • 6 CYL
  • 159 MILES
So, it first started off I tried to get the three windows working that weren’t working. The only window that was working was the driver side, so I pulled his switch out and I took a paper clip, and I started touching each terminal and what I did was touch too hot together And I got a spark now all of a sudden, the windows are working, but not the high beams. No turn signals, no wipers. Help.
Tuesday, August 22nd, 2023 AT 9:16 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
It sounds like the main window switch needs to be replaced, but you need to check all fuses, here is a guide to help and the fuse locations to help:
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Tuesday, August 22nd, 2023 AT 2:04 PM
