I changed my car battery and after that the key remotes are no longer working and the OBD-II port is no longer getting power.
Wednesday, March 27th, 2024 AT 6:23 AM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like you had a power surge, and some fuses might have blown. Let's use this guide to check the fuse and in particular the fuse for the OBD2 port which is fuse# 18 in the fuse panel under the hood on the left side.
Also, can I ask if the battery was connected backwards? Check out the images (below). Please let us know what happens.
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, March 27th, 2024 AT 9:42 AM
MEHDIAB
MEMBER
Hello. Changning fuse 18 worked so thank you very much for your help. I think there was surge from one of the boosters I used to start the car when the battery was dead. Thank you again!
Wednesday, April 3rd, 2024 AT 10:22 PM
KEN L
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
