Code P0219B?
JPUTNAM
  • 2016 DODGE RAM
  • 5.7L
  • V8
  • 4WD
  • 83,500 MILES
I had the bank 2 upstream sensor replaced and the same code came up after about 10 miles so I took it back to the shop and he's got me running sea foam through the gas I have run 32oz through with about 9 gallons gas and it's still the same code coming up. The truck is running fine like it always has with no problems.
Monday, April 1st, 2024 AT 9:36 AM
  • 108,489 POSTS
The code could be the result of a few things. Most commonly, an exhaust leak pre-O2 sensor is the cause.
I attached the diagnostics below. Take a look through them and let me know if they help and if you are comfortable performing them.
Monday, April 1st, 2024 AT 4:36 PM
