P1443
BMXWAYNE
  • 1996 FORD RANGER
  • 285,000 MILES
What are all possible causes of the code p1443 evap canister purge low/no flow and what are the most common ones the purge valve was replaced a couple of years ago and one of the hoses just the other day what all testing can be done to check all possibilities
Sunday, May 12th, 2013 AT 7:13 PM
HMAC300
  • 48,600 POSTS
Get a smoke test done on the system that will tell you whats wrong. Check to make sure your gas cap has at least 3 clicks after a fillup
Monday, May 13th, 2013 AT 7:07 AM
BMXWAYNE
  • 58 POSTS
I was wanting to know what all I can do my self to diagnose the problem and not take it to a shop
Monday, May 13th, 2013 AT 7:26 AM
HMAC300
  • 48,600 POSTS
It has to have a smoke test to see where it 's blocked unles syou wan tto try spending money on a evap canister purge valve and seeif it fixes it but you'llneed a scanner to erase the code.
Monday, May 13th, 2013 AT 7:27 AM
BMXWAYNE
  • 58 POSTS
How can I do a smoke test on my own I am trying to save money by not going to a shop because I am on a very tight budget
Monday, May 13th, 2013 AT 7:30 AM
HMAC300
  • 48,600 POSTS
You can't it's specialized equiptment. It is nt' smoke anyhow.
Monday, May 13th, 2013 AT 7:32 AM
