Brake light pedal position sensor wiring diagram needed?
KRISTINSAMANS
  • 2005 CHEVROLET MALIBU
  • 2.2L
  • 4 CYL
  • 130,000 MILES
Hi, I need the wiring diagram for the brake light pedal position sensor in my car listed above please.
Tuesday, April 2nd, 2024 AT 7:46 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,468 POSTS
Sure, here are the brake light switch wiring diagrams to the BCM. Check out the images (below). Let us know if you need anything else.
Tuesday, April 2nd, 2024 AT 8:37 PM
KRISTINSAMANS
  • 8 POSTS
Okay, so I wired the switch, and my brake lights are still on when I turn off my head lights, they shut off but then I have none. I don't know what else to do or why that even happens.
Wednesday, April 3rd, 2024 AT 4:11 AM
KEN L
  • 43,468 POSTS
You might need to calibrate the brake light switch, here is how:
BRAKE PEDAL POSITION SENSOR CALIBRATION
CALIBRATION CRITERIA
The brake pedal position sensor (BPPS) receives a low reference signal and a 5-volt reference signal from the BCM. Whenever the brake pedal is applied, the BPPS applies a variable voltage signal to the BCM through the stop lamp switch signal circuit. The BPPS calibration must be performed after the BPPS or body control module (BCM) have been serviced. The calibration procedure will set BPPS home value. This value is used by the BCM to determine the action of the driver applying the brake system and to provide this information to the vehicle subsystems via the class 2 communication bus.
CALIBRATION PROCEDURE
- Install a scan tool.
- Turn ON the ignition, with the engine OFF.
- Select Diagnostics.
- Select the vehicle.
- Select Body and Accessories.
- Select Lighting Systems.
- Select Special Functions.
- Select BCM.
- Select the BPPS calibration procedure and follow the directions displayed on the screen.
Please go over this guide and get back to us.
Wednesday, April 3rd, 2024 AT 8:33 AM
KRISTINSAMANS
  • 8 POSTS
Does it matter if my car is a 2005 Chevy Malibu classic? I just learned there was a regular Malibu and a classic version.
Tuesday, April 9th, 2024 AT 11:15 PM
KEN L
  • 43,468 POSTS
It should be the same procedure.
Wednesday, April 10th, 2024 AT 9:18 AM
KRISTINSAMANS
  • 8 POSTS
Okay, cool, that's what I thought. Now how do I do this calibration meaning what is the cheapest tool I need to get or place I can go? I am very low on funds now.
Thursday, April 11th, 2024 AT 1:40 PM
KEN L
  • 43,468 POSTS
You can search Amazon for a scanner that can go into the BCM, if it doesn't work you can send it back.
Friday, April 12th, 2024 AT 5:39 PM
KRISTINSAMANS
  • 8 POSTS
I have a Innova 3170RS but I can't figure out how to do the calibration with it.
Friday, April 12th, 2024 AT 6:47 PM
KEN L
  • 43,468 POSTS
Innova has a support line, I would give them a call.
Friday, April 12th, 2024 AT 7:32 PM
