Will not start after overheating?
INDYALEWIS22
  • 2008 DODGE CALIBER
  • 19,889 MILES
Hello, I was wondering what it would mean if my brother replaced my starter and battery, but the car still won't start. It stopped on me due to overheating I guess and it was smoking. He said oil leaked into my engine but I'm still not sure what to do.
Friday, February 2nd, 2024 AT 7:44 AM
BORIS K
  • 766 POSTS
The best check to do is to conduct a compression test.
This could then point to a possible mechanical issue with the engine
Some interesting reading:
https://www.2carpros.com/articles/symptoms-of-low-compression
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
and
Video on compression test:
https://youtu.be/J3j85hg0d-4?si=8DyE55nXWIb90LYR
Expect to see 150-160Psi on each cylinder for good compression readings.
Cheers, Boris
Friday, February 2nd, 2024 AT 9:09 AM
