Radio wiring diagrams needed
LEARY DLB CURTIS
  • 2016 KIA OPTIMA
  • 2.0L
  • 4 CYL
  • TURBO
  • 37,000 MILES
Car listed above is an SX with Harman/Kardon and sub woofer. Just looking to add subwoofers using a full range speaker. I need the rear speakers wire colors.
Monday, December 28th, 2020 AT 1:57 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached the radio wiring diagrams you requested for your car below. I'm not sure which audio system your car is equipped with so I included all of them. There are navigation with amplifier, navigation without amplifier, and without navigation. I've cut the pictures in half so you can view larger. Hope this helps and thanks for using 2CarPros.
Wednesday, March 10th, 2021 AT 7:08 PM
SKUBASTEVE
  • 2016 KIA OPTIMA
  • 32,000 MILES
Vehicle listed above is the EX model.I have the touchscreen with backup cam and nav. I've recently ordered a LC2i so I install two amps and a sub while keeping the stock head unit and all it's functionality. I can't seem to find any wiring info at all for this particular year and head unit. Any help anyone could provide would be greatly appreciated.
Wednesday, March 10th, 2021 AT 7:10 PM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
We need a little more info on your car to get you the right diagram. Can you tell us if your car is the hybrid or can you add engine information? Also, I've attached below a picture of the different stereo system systems. Can you tell me which one is yours? Hope this helps and thanks for using 2CarPros.
SKUBASTEVE
Hi Danny,
It is not the Hybrid version. I believe the engine is a 2.4L. I'm pretty sure the second stereo listed in your image will probably be the correct one. I do have navigation but not the premium Harman Kardon upgrade that came with an external amplifier so that one seems to be the most accurate description.
DANNY L
  • 5,648 POSTS
Hello again.
Here are the stereo wiring diagrams you requested. I've cut them in half so you can view larger and attached them below. Hope this helps and thanks again for using 2CarPros.
Danny-.
MARIEBOO
  • 2014 KIA OPTIMA
  • 120,000 MILES
Radio wiring diagram for the car listed above lx model.
SKUBASTEVE
This looks like exactly what I need. Thank you so much for your help.
Normally I would attach all the diagrams for the different options so you can choose yours, but you have quite a few options that if I post all of these it will just get confusing. So can you take a look at these options and tell me which you have?
Thanks
Please see below for the options.
DANNY L
  • 5,648 POSTS
Hello again.
You're welcome ! Please feel free to use us again in the future. Thanks again for using 2CarPros.
Danny-
MARIEBOO
I have no Navigation. Not sure about the other. I have a 4 doors.
Okay. Sounds good. This should be what fits your vehicle. Let us know if you need other info. Thanks
IAN`
  • 2009 KIA OPTIMA
  • 50,000 MILES
I cant find it any where
its a kia optima lx with standard audio
RIVERMIKERAT
  • 6,110 POSTS
Here ya go. I found all wiring diagrams for every kind of radio that came in that car.
Check out the diagrams (Below)
Cheers
BEN RODRIGUEZ
  • 2008 KIA OPTIMA
  • 2.4L
  • 4 CYL
  • 226,344 MILES
My bro cut the stock harness and have no clue to what wire is which. Radio, steering control, aux, with cruise, without navi, with amp. Need help fast.
Sorry to hear that. I am attaching the entire radio wiring diagram for the options you specified. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Let us know if you have other questions. Thanks
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
Here are the wiring diagrams for the radio and a guide to help you test the connections:
05KIA
  • 2005 KIA OPTIMA
  • 12,000 MILES
I can't find the wiring, I have to gray cords that's not connected to anything and a pink cord that's not connected my stereo doesn't cut on at all. The stereo is a pioneer.
KEN L
  • 43,351 POSTS
I know this is an old post but I wanted to get you the wiring diagrams so you can see how the system works in case you still need them. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
RDMERCER BERNITT
I could use the same help here with putting in a loc, I have a 19 Kia optima SXL 2.0 T. It has navi. I'm pretty sure it's the 10 speaker 600-watt h/k system. As it's called, lol. I have amplifier numbers if those will help, not sure which ones you would need to know, any and all help will be greatly appreciated. Thanks, R
Sunday, March 6th, 2022 AT 10:19 AM
KEN L
  • 43,351 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Wednesday, March 9th, 2022 AT 11:32 AM
