How to remove the temperature sensor?
JMAHURT
  • 2012 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 100,500 MILES
I have a Limited model that will also accept flex fuel. I can see the temperature sensor but I'm not sure how to remove it. Does it require that the starter be removed? Thanks
Wednesday, March 6th, 2024 AT 3:22 PM
  • 108,489 POSTS
This has a cylinder head temperature sensor. It is mounted on the cylinder head.
I attached the directions below for replacing it. Take a look at the directions and let me know if they help or if you have other questions.
Wednesday, March 6th, 2024 AT 7:26 PM
JMAHURT
  • 5 POSTS
I can see the sensor and even unplug it from the wiring. I just can’t get a wrench or ratchet on it. My question really relates to what should be removed to gain access. I will take another look at it this weekend. Thanks
Thursday, March 7th, 2024 AT 10:28 AM
  • 108,489 POSTS
From what I'm seeing, you should have access. Do me a favor. Take a couple of pics of the sensor so I can see what you are faced with. I'm asking because I checked two different manuals and neither of them indicated things being removed other than the sensor.
Thursday, March 7th, 2024 AT 5:15 PM
JMAHURT
  • 5 POSTS
The cylinder thermostat has yellow tape.
Saturday, March 9th, 2024 AT 9:28 AM
JMAHURT
  • 5 POSTS
Looks like it might require the intake manifold to be removed?
Saturday, March 9th, 2024 AT 9:36 AM
  • 108,489 POSTS
Many do require the intake to be removed. However, if I am seeing it in the pics you sent, it looks easily accessible. Am I looking at the correct thing?
Saturday, March 9th, 2024 AT 5:27 PM
JMAHURT
  • 5 POSTS
I wanted to give you an update and one more pic. The temperature sensor has yellow tape and to its right is the starter. I had to remove the 2 bolts holding the starter in place and move it over to the right. Once the starter was moved, I had the room to get a long socket with extensions over the sensor for an easy removal!
Tuesday, March 12th, 2024 AT 4:25 PM
  • 108,489 POSTS
Thanks for the update. I'm glad you were able to get it taken care of. I have no idea why things have to be made so difficult to work on anymore, but it must save money with production.
Regardless, thanks again and feel free to come back anytime in the future.
Tuesday, March 12th, 2024 AT 7:31 PM
