Replacing flywheel
MFRANCE
  • 1998 MERCURY SABLE
  • 3.0L
  • V6
  • 150,000 MILES
How long does it usually take to replace a flywheel/flexplate
Wednesday, April 13th, 2016 AT 12:13 PM
HMAC300
  • 48,600 POSTS
This is a big job and takes about 8.5 hours at the shops labor rate of $85.00 to would be $722.50 Here is a video and diagrams below to show you what it will take to change the flywheel.
This video will give you an idea of how the pull the transmission, its a different car but the procedure is the same.
https://youtu.be/6N6b5F2ChyE
Cheers
Wednesday, April 13th, 2016 AT 12:25 PM
LIZZY55
  • 2005 MERCURY SABLE
  • 6 CYL
  • FWD
  • 73,456 MILES
My mechanic says the labor to install new fly wheel and starter is high because you have to drop the engine. Is this true?
Monday, October 1st, 2018 AT 11:57 AM (Merged)
CARADIODOC
  • 33,765 POSTS
Either that or remove the transmission. The flywheel / flex plate is between the transmission and engine and connects the two of them together. It is indeed a big job to replace it. You can expect it to take between six and eight hours.
SHAWN EAKER
  • 1994 MERCURY SABLE
1994 Mercury Sable 6 cyl Two Wheel Drive Automatic 150k miles
do I have to drop the transmission to remove the flywheel.
  • 31,937 POSTS
Hi there,
yes you must remove the transmission.
Mark (mhpautos)
MERLIN2021
  • 17,250 POSTS
Yes. Sorry!
