Code P0141, running rough?
LIONELL8732
  • 2007 MERCURY MILAN
  • 2.3L
  • 4 CYL
  • 191,000 MILES
Hello, I need some help trying to figure out what's going on. I attached a video for you all to hear the engine running. I recently changed the ignition coils, spark plugs, fuel injectors, downstream oxygen sensor. I also stripped down both connectors and replaced them with new connectors for the up and down oxygen sensors. Hooked up the scan tool and in getting a P0141 on every starts up. The freeze frame shows the downstream sensor reading at 0 voltage and upstream at 22 voltage. This is the only code that's on.
Saturday, May 11th, 2024 AT 8:09 AM
  • 108,489 POSTS
The problem is likely a wiring issue. I attached the diagnostics below. They are somewhat extensive and will require a bidirectional scanner.
Take a look through the diagnostics and let me know if you are comfortable performing them.
Saturday, May 11th, 2024 AT 9:33 PM
LIONELL8732
  • 140 POSTS
Checked all the wiring and the wiring r fine may have to take it to the dealership for further assistance
Thursday, May 30th, 2024 AT 6:33 AM
